outnaboutExplorerDec 20, 2014adding a heat stripI have a 2013 Montana and I want to install a heat strip in the AC. Can this be done and does anyone know if it might be pre-wired to the thermostat
22 RepliesReplies sorted by NewestShow Morerv2goExplorer IIDec 20, 2014I had a heat strip in the air conditioner of a previous RV. I really did not like it. Too much air flow for the amount of heat. I found that a small 1500watt portable heater worked much better. Newer units may be better.sch911ExplorerDec 20, 2014Since Montana didn't manufacture the A/C unit we'll need to know which brand/model of A/C unit you have?
Related ContentAdding Heat StripsAdding power outlets in slide with no wiringChanging heat pump to heat stripHeat stripDometic Heat Strip DMR702
