slotsavegas
Apr 10, 2014Explorer
Adding BR A/C to Styrofoam insulated roof
I have removed a Fantastic Fan from my bedroom vent. I have run the 120 Volt wiring from this vent to an 20 Amp outlet I installed in the side of my 5th wheel.
I have purchased a 13.5K Coleman Mach 8 A/C.
Now I see that all the support I have around that vent is Styrofoam sandwiched between the roof and the interior wall board.
I have run a wire into the Styrofoam to a depth of about 6" on three of the four sides and have not found any wood or aluminum supports.
Will the Styrofoam alone be enough to support the installed weight of the A/C and will the compression bolts that compress the foam seal cause the Styrofoam to collapse over time and loosen the seal causing leaks.
Anyone know if they have an A/C installed in a vent this way ?
Any suggestions ?
Any suggestions ?
