- goducks10ExplorerMy slide has 120V.
- Matt_NYExplorerThanks for the replies! ependydad, Those photos were most helpful.
- Community Alumni
time2roll wrote:
Mine (oem) has a J-box to some rubber covered cord supported by a spring to keep it out of harms way.
Mine has a similar setup for both living area slides and one has the stereo and tv in it. Only difference is that the wires are curled around the hydraulic rams instead of the use of a spring. No problems in 14 years. 120 volts in the slides is a common installation in most units I've seen. Look at the number of kitchen slides out there now. - Mine (oem) has a J-box to some rubber covered cord supported by a spring to keep it out of harms way.
- ependydadExplorerHere is how they did it on one of my slides:
https://flic.kr/p/26kMoGg
Here’s what I’m going to reuse for the other:
https://flic.kr/p/25fX8L5
https://flic.kr/p/23A2rss1 - ependydadExplorerI’m actuvely in the process of it. My plan is to get stranded marine wire for a run from either a junction box or maybe the whole way to an outlet that I’ll tap off of. Anything outside will be put into wire loom.
Under the slide already has holders and 12v going to it (for lights). I’ll reuse the wire hanger/support from that.
Then up through the floor to on-wall wire mold and on-wall outlets. - djousmaExplorerMy 5th has 120v outlets in all 3 slides. That said, I assumed all did. Agree Romex won't last long. I assume they probably use twisted strand wire? Just a guess though.
- donn0128Explorer IIRomex does not like to bend. Thats one reason RV mfgs dont do it.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 14, 2026
