Me_Again
Oct 19, 2014Explorer III
Cummins12V98 wrote:
Change to a set of GY G614's and your troubles will go away. They are the only ones who will backup and pay for damages in the rare chance they should fail. GY G and H tires have been extremely dependable since around mid 07. I have ran two sets of G's and one set of H's and never a flat over many thousands of miles.
They are not CHEAP but you will get what you pay for.
Weigh your tires and use the heaviest weight to determine what air pressure to run. Weight/inflation charts are available for all tires. GY says to use the chart and add 5psi to what the chart says if up sizing load range.
Most likely you will be running 85-90psi.
That might be a little low on inflation pressure for a G614 on his trailer. At 80 pounds inflation the G614 is rated to 3042.
85 = 3170
90 = 3300
95 = 3415
100 = 3550
105 = 3675
110 = 3750(G)
http://www.goodyearrvtires.com/pdfs/tire-care-guide.pdf
Chris
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
