othertonka
Feb 08, 2014Explorer
The lights always run from the battery. When plugged into shore power, the 110 V AC goes to all the outlets and also powers up the Converter, the converter charges the batteries, the lights run from the battery. Seems like you are OK. To check if the converter is working, use a multi meter and check the voltage at the battery, if it is working, the volt reading should be about 13.6 volts when plugged in. unplugged the battery voltage should be about 12.7 for a fully charged battery.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
