donn0128
Apr 24, 2015Explorer II
Waste of money. What you really need is more truck. There is nothing you can add that will cure overloading. If you dont believe me, load up and go to a set of scales for some accurate weight numbers. Compare those numbers to your trucks factory GVWR, GCWR, RAWR and you will have the answer.
The only model that I see that comes close is either 37 or 41 feet long. The 37 footer has aa GVWR of just under 14,000 pounds, meaning you likely have a pin weight close to 3000 pounds.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
