cummins2014
Jun 04, 2015Explorer
Cummins12V98 wrote:
With only 3,200# pin you should not have need to do anything to "level" your truck. Blisten's would have helped and not running over 55 psi on your rear tires. Airbag kingpin also helps!
Tell that to my 2014 Ram 3500 with about 2500 lbs on the pin, it needs a little leveling, but the truck sits so darn high in the back I need it to sit down as much as possible to help level the fifth wheel .
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
