rgstarnes
Jun 09, 2015Explorer
07PSDCREW wrote:RCMAN46 wrote:
If the OP will give us the CAT scale numbers I am betting we may find his pin weight percentage is way low.
Number one cause of porpoising is low pin weight percentage.
After we get actual CAT scale numbers then we can intelligently discuss if he has enough truck. Right now we are only guessing.
I didn't read all 7 pages, but I agree here. I discovered that by adding water to my front mounted fresh tank made my truck ride soo much better than when we ride with the tank empty. We were going to a park with no hookups and I filled the freshwater before leaving. What a difference!
Here are the CAT weights with trailer:
steer axle---4480
drive axle--6500
trailer axle--11020
Gross weight--22100
without the trailer:
steer axle--4480
drive axle--3480
gross weight--7960
Trailer gross weight--14040
Pin weight--3020
truck rating on sticker
steer axle--4800
drive axle--6800
gross weigh--11000
tire rating-- 3620 each
gross pulling weight of 5th wheel--16,300
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
