RCMAN46
Jun 11, 2015Explorer
To the Op.
When I take the weights you supplied I get a trailer weight of 14140 Lbs.
With a pin weight of 3020 that gives a pin percentage of about 21%.
With long trailers and depending on how much overhang you have on the rear 21% is probably on the low side.
If you were to redistribute some weight if possible and get the pin percentage close to 25% you may see a dramatic change in the amount of porpoising.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
