MFL
Jul 19, 2020Nomad II
CLHEJ wrote:
Thank you all.
FWIW, we have a 41' five with 4 slides. 15k ac unit in the living area and a 13.5k unit in the front bedroom.
This info helps, and changes my thought of "something is wrong". That is a lot of space to cool, and the multiple slide roofs, that are not insulated as well, may add to cooling issue.
I agree with others, check for cooling loss into roof, around vents, seal any area that could leak. With ceiling AC covers removed, look up, check for any areas needing a better seal, taping with foil tape.
If you find no issues, you may need to add the 3rd AC, to maintain a 73 degree setting in high heat conditions.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
