time2roll
Jul 24, 2020Nomad
Possible you are icing up. Remove the inside covers and inspect. Look for ice on the evaporator coil. Look for the freeze sensor is placed on the evaporator coil. Plenty of posts where the sensor was poorly installed or has fallen away.
Also check the plenum divider. This separates the air in and air out. If it was poorly installed much of the air just circulates within the unit instead of being forced out to cool the RV.
I had both these issues and I am sure some of my precious cool air leaks into the ceiling cavity. You do have a lot of space to cool and the air units should be running near continuous from sun up to sun down with some cycling overnight.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
