mtofell1
Jun 17, 2019Explorer
If the trailer has been winterized and the lines are empty you will get a lot of spitting of air before water is produced. So, be sure you have let it run for a while before giving up. You really can't hurt anything by just letting air spit out.
I know some newer trailers have valves to switch and allow filling the fresh tank from city water connection so I'm not sure if that could have some impact. You might also try to hookup to city water and give things a try to see if it works. If the pump is running an you're spitting out air is sounds like things are working. Be sure you have plenty of water in the tank and you're not on a steep angle. I know when I'm parking in front of my house on an angle the water pump will often dry-fire due to all the water in the tank running to on end.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
