laknox
Jun 19, 2019Nomad
OK, older model, so no "convenience" center. Most likely culprit for air is the inlet side of the pump, IMO.
As for dinging the cab of your truck, were you backing up or going forward? If going forward, then your truck, IMO, has one =tight= turning radius...assuming you had the slider in the rear position. If you were backing up, ALL FWs will hit the cab; the slider just gives you more time/room before you DO hit.
Lyle
Lyle
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
