spd522's avatar
spd522
Air lift to 5th wheel with Mor-Ryde
We have a 2003 Carriage Cameo. Our concrete driveway angles and has enough slope that I can't park it into the area we had put in just for that purpose without the rear hitch dragging. I have tried backing in trying a different angle but it still drags.
I tried those rear caster wheels that are made for this but due to the angle, only one wheel makes contact at a time, putting all the stress on the one wheel. Consequently, the wheel can't handle it and shattered.
Our 5er has Mor-Ryde suspension. Is it possible to add air lift or air shocks to raise the unit up when parking and then back down for normal travel and stationary use?
  • I will try the boards but I am not sure they will stay put trying to drive up on them.
  • As suggested above, can you lay down a piece of 2x10 or 2x12 lumber under the tires to lift the trailer just enough to clear the hitch?
  • My driveway has a high angle slope from the street. We're on our third 5th wheel and I thought all of them would drag when we brought them home. But they just barely clear when backing at an angle. I was prepared with some 2x12 boards to put in the valley but havent needed them.
    Before I spent money on modifying the suspension I would look at what you could do to temporarily reduce the depth of the valley between the street and driveway.
  • There are several different flavors of MORryde suspension. Are you talking about the independent suspension or the CRE3000 or SRE4000 equalizer systems? If independent suspension (which we have), I don't see any way of adding air bags to the trailing link suspension geometry.
    Rob
