Cummins12V98
Jul 29, 2018Explorer III
Itching2go wrote:
While I do know that it is less than 100 lbs, which is the rated max for the Airlifts that I have, I don't recall exactly what the loaded pressure is, but believe it is around 70 lbs or so... likely a bit less. Since I air them up before I hitch, I don't really pay that much attention to the loaded pressure. If I had the automatic air pump installed with the bags, that would likely be a different story.
Just to give you an idea what happens to unloaded pressures when hitched. I would run 5psi unloaded and once the 4,500# pin was applied the bag pressure went to 30psi.
Sounds like a lot of pressure on a 3500 with 3k pin! With 3k you should not even NEED bags but they do improve ride if adding enough air to control axle movement. To ME it sounds like too much air and would cause a poor ride.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
