- Cummins12V98Explorer IIIYou really did not need bags for such a light RV. BUT they can improve ride by starting out with 5psi unloaded then hitch up and check the pressure, it will have increased. Bottom line add just enough air to bring truck back to "LEVEL" and do NOT think you need to make the truck set the same height as without the RV. You want the bags to be there for support and control axle bouncing. If you have not done so throw on a set of Bilstein 4600's.
I am betting with 45psi UNLOADED adding the RV makes for a very rough ride!
Air your tires based on LOAD. - goducks10ExplorerAn 8500 lb 5er would have a pin of about 1700 lbs. Thats not much at all even for a 3/4 ton. I use bags with a pin of about 1800-1900 lbs in my Ram 2500 and only put 25 psi in them. That gives me a little more side to side stability. Anymore and the rear of the trucks to high. with 25 psi the trucks sitting down about 2" in the rear which puts it 1" higher than the front and leaves the 5er about 1/2" high in the front.
I've tried 20, 25 and 30 psi. 25 is the best for ride and overall setup.
50 psi would be way over the top for me. Just wondering why you have bags and why you need 50 psi? Are you hauling a lot in the truck bed? - Super_DaveExplorer
Lynnmor wrote:
Dave H M wrote:
Yep used for level up. Mine works if i put 25 in unhooked. Then hook up.
I run zero when unhooked.
Check your instructions, mine says 5 lb. minimum.
I guess some people have reported having problems pinching them if running empty. I've run mine for 12 years empty when not hauling and never had a problem. With a 1 ton dually my empty ride is harsh enough that even 5 lbs. adds unwanted bounce. - LynnmorExplorer
Check your instructions, mine says 5 lb. minimum. - Dave_H_MExplorer IIYep used for level up. Mine works if i put 25 in unhooked. Then hook up.
I run zero when unhooked. - jkilroyExplorerGoing for the best ride with 5th wheel attached, not ride.
- Keithk3628ExplorerWhat super dave said, I installed them to level my F250 first with the 5ver, then later with the Lance Truck camper, 50 lbs would level my 5ver and when empty i ran 5-10 lbs. 65 lbs with the Lance.
I had Firestone air bags and were very happy with them, they were still working when I traded my 99 F250 - B_O__PlentyExplorer IIThey are designed to level the truck when hitched, nothing more. The amount of air in them will vary with every setup.
B.O. - Ed9824vExplorer5-100 psi mt I run at least 5 psi about 60 psi I run with 5er
- Super_DaveExplorerIf you are using the air bags as designed to level, it is simple as taking some before and after rear bumper measurements.
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 03, 2025
