jaycocamprs
Aug 05, 2023Explorer
Cummins12V98 wrote:CoMoCo wrote:
Mmaxed - I have one of these Trailairs on my 2022 Cedar Creek and shared the same concern about the angle of the lower jaw. I have no problems hitching and unhitching.
There are 2 things I don't like about the Trailair - it looses air pressure and forces me to carry a compressor to ensure it is filled with air. And I don't like how it sits on my Curt Q24 hitch - this hitch is articulating and the head does not sit level when hitched up - it tilts slightly downward, towards the front of the truck.
Lippert says both of these things are normal, I disagree. I have had the airbag in the Trailair replaced once under warranty due to leakage and the replacement is just as bad. Maybe my dealer is the culprit and didn't install it correctly. I am working with my dealer to get the current air bag replaced.
Have you applied 100psi to the bag? That can help with air loss. The CURT design is the issue not the TrailAire. The heads pivot point being several inches below the kingpin connection is. This can lead to chucking, a common complaint against the CURT. B&W pivot point is right at the level of the kingpin.
No it's the TraiAir, Head points down on mine, even with a B&W. The Curt may lead to chucking, but the pin plate of the TrailAir does not sit level.
Air bag leaking, yea that's normal Lippert quality.
About Fifth Wheel Group
