BigD2's avatar
BigD2
Air suspension advantage or not
I have a 2011 Ford F250 XLT 6.7L Diesel and I pull a FR Silverback LTDTS 33 foot fifth wheel. I am a little below max weights for truck and trailer. I was thinking about adding rear air suspension to help stabilize the ride.
Is this money well spent, and what are potential advantages?
Thanks In Advance
Dick
  • ventrman wrote:
    Would't Airshocks work as well?
    My brother once ripped off an upper shock mount while using air shocks. The airbags have a more secure mounting.
  • May want to take a look at "timbrens". No air required. Cheaper than air bags. Less maintence, uses regular suspension when not towing. Several of us in my Good Sams chapter have them on our 2500's and 250's.
  • I have used air bags on the last three Rams. The last two were Air Lift Ultimate. they have their own joyce and can run without air. Anyway the advantge for me is that they smooth out the ride. I tow heavy as you can see from my sig. I added a compressor this time so I can adjust anytime I want.
  • Another advantage of OBA (on board air) is the ability to top off air in tires whenever you stop, and not be limited to gas stations. Also useful for the kids toys.
  • BigD2, I have the Firestone Ride Rites on my F350 just to level things out and soften any bounce. Loaded I only run 18-20 lbs of air. Unloaded about 5 lbs. I put them on myself. No big deal. Pretty straightforward.
    Good luck. Enjoy the road.
    bigdon68
  • The advantage of airbags is that you can deflate them when not towing. Many 3/4 ton PUs are the same as their 1 ton brothers, except for the rear springs. By using airbags on a 3/4 ton, you can have a softer/more comfortable ride than a 1 ton, when not towing.
    EDIT. Some people add an onboard air tank and/or compressor to their installation, to facilitate adjusting airbag pressure in remote locations. (Away from a compressed air source.)
