agesilaus
Feb 23, 2016Explorer III
The height isn't much of a problem. Most 5vers and other RVs are over 13'. The length will restrict how many federal campgrounds you can use. For example there is only one valley CG in Yosemite that a big RV will fit into (North Pines) and only some of the sites in that CG would work. 40 ft is on the long side tho, a 35 ft RV would give you more flexibility.
Most commercial CG will work and you can find federal CG that work too with some effort. We camped in Lassen and Yosemite for example.
Not sure if this will cross over to your RAM but we get 9-12 mpg with our F-350. Mileage depends on winds and road grade. Most of the time we get 10-11 mpg.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 20, 2026
