The Anderson is my first 5'er hitch. I did a lot of research on other brands and styles and found several that were very good and would have worked well for my set up.
I was very impressed with the Anderson due to the straight forward, simple and light weight design.
I liked the ability to raise and lower the hitch ball to fit my set up as well as the overall strength of the product.
I also purchased the levelers and the rapid jack which are very well made and do the job nicely.
I have not had any trouble with rust on the unit yet but if I do, it will be very easy to touch up.
I may move to the aluminum model later on when I can afford it since it's only 30 lbs.
