j2catfish
Jan 02, 2014Explorer
X2 - finally someone has stated the design (correct) amp draw. Always plan for the 80% and you will probably have no problems with circuit breakers popping. If this is not sufficient, about the only real solution is to re-engineer the main power to the coach for 50 amp service.
Just my take, your opinion may vary but check with a good/experienced electrician.
Catfish
Catfish
pianotuna wrote:
Hi,
The continuous duty is 80% of 30 amps. i.e. you really only have 24 amps available for constant use.
The fridge draws more like 4 amps not ten.
For brief periods of time (read a second or two) drawing more than what the breaker is rated at will rather rarely trip it.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
