- frizzenExplorerMany thanks to all for the replies
- BayleyExplorerI also have the Anderson "Ultimate" 5th Wheel Hitch as well as the levelers and rapid jack. The Anderson product is top notch and performs extremely well. I haven't had to use the rapid jack yet but if it performs as well as the levelers do then I will be a happy camper!!!
- golf_bearsExplorerI have a set and have used them a few times. Last time I used them one of them split in the middle. Called the company and they sent me a replacement right away. They work very well as advertised.
I think the reason mine split was because I was on a crush rock RV site. The crush rock does not let the load transfer across the full face of the leveler. The leveler sits on the high points of the crush rocks and that causes high stress points.
I still think they are great for leveling as long as the company is willing to replace the split ones. After they get a bunch of them replaced I'm sure they'll change the design and beef them up. - Heap64ExplorerWe have a set and they have worked well. I could see with soft ground that they aren't wide enough? I would carry a few boards to place under them if needed.
- roadking59ExplorerI ordered the chocks and rapid jack... Their fifth wheel hitch looks very interesting... Very simple design.
AJ - alcaracuExplorerlove them! especially on our single axle Hi-Lo.
- old_guyExplorerI hope so since I ordered some yesterday.
- ScottGNomadYes they are.
I bought a set and they are one of the best things to come to trailers in a long time. - Nutinelse2doExplorerAndersen Levelers
Andersen Levelers
There's 2 threads on them. If you need more, might I recommend a search?
Since no one has done so yet, welcome to the forums. - Brodie3AzExplorerThere have been several threads regarding these products. Use the company name to search this website.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
