- valhalla360NavigatorHaving seen them on a few youtube videos, I don't see where they are significantly better than a few pieces of 2x8.
Generally will find a different site if it needs more than 2 boards. - EsacnjExplorerI am also concerned that when you try to take the chock out from under them that you may have to back up to release the pressure to remove the chock and may come off the back of the leveler which wouldn't be good.
- cbshoestringExplorer IIHad one slip, I haven't used since. I feel much more secure driving up on the interlocking blocks.
- pianotunaNomad III
fj12ryder wrote:
Are speaking of the angled ones you drive up on? Andersen makes several types. I have seen it mentioned that people have had them break, but don't know that for a fact.
I know it for a fact. One of mine broke while I was sleeping. It was quite a loud noise. - DurbExplorerThey work great, but will slip on some surfaces so use the rubber pad which fixes the problem. I did have one break on asphalt (10,500# trailer). I emailed them a picture of the broken unit and Andersen sent out a new one swiftly.
I did try a different brand off Amazon as it looked heavier duty and came with a carry case. The ramp angle on it was too steep and the trucks e-brake wouldn't hold on it to get the chocks in. The smooth radius on the Andersens is a better design than the Amazon product.
Some complain they interfere with chocking their tires. I use Rotochocks so it isn't an issue for me. - fj12ryderExplorer IIIAre speaking of the angled ones you drive up on? Andersen makes several types. I have seen it mentioned that people have had them break, but don't know that for a fact.
- spoon059Explorer III LOVE mine. Find the low side, put out the Andersons and slowly drive until you are perfectly level.
- CA_TravelerExplorer IIIYes
About Fifth Wheel Group
19,025 PostsLatest Activity: Oct 09, 2025
