Jhurk wrote:
Yes my release cable is all the way out. It is always easy to pull the cable. I'll try spraying the ball with silicone to see if that works? Maybe a spray of silicone to the release cable from inside the adapter may work to. I'll give Anderson a call next week.
I wouldn't use silicone. For trailer parts I always use Dry Lube (like the stuff they sell as Slide Out Dry Lube). But I wouldn't even do that until after you talk to Andersen. If you look inside the pin adapter you can see that Andersen has a permanent lube coating already there. As to lubing the sliding in/out pin that is controlled by the cable, if that free easily, putting silicone on it could cause it to collect dirt. Talk to Jason.
