- SoCalDesertRid1Explorer IIOn the B&W, the weight is not carried by the bed floor. It is carried by the square bar that inserts into the square gooseneck ball hole. The bar mounts into the gooseneck hitch the same way the ball mounts into it. The bar bottoms out on the bottom of the hole, just as the ball bottoms out in the hole, and is pinned in place by the sliding pin that also locates the ball.
- rhagfoExplorer III
Me Again wrote:
sayoung wrote:
Searching_Ut wrote:
As Me-Again pointed out, all of the weight is carried by the bed of the truck when using the Andersen Ultimate hitch. I'd have to look in depth at the truck bed to see if I thought it would hold up to the weight and potential flexing. Personally I probably wouldn't use one with 5er of any size if I had an aluminum bed. That said, I would avoid the aluminum bed if possible as I use my bed for a lot of stuff, much of which would seriously scratch and gouge aluminum.
There is so little wieght on the bed there is a set of filler pads you glue to bottom when you put in truck 1st time . Line them up with the dips and this stops the small amount of twist some have, usually less than 1/2 in is what I experienced . No bed bending but then I drive a real truck, Chevy :B
Wrong! All the weight is carried on the bed floor. Like safety chains Andersen is not completely truthful on such things.
Ask them if they are willing to warranty any bed damage and see what they have to say. While you are at it ask Ford if they will warranty their new aluminum bed if an Andersen or Companion hitch dents it.
Chris
X2 to what Chris stated, this is true for both the Andersen ultimate and B&W Companion place all the pin weight on the bed floor. The hitches are located by the GN ball, but the weight is carried by the bed floor. - cummins2014Explorer
johndeerefarmer wrote:
I am interested in the Anderson Ultimate (gooseneck ball mounted version) and want to know how much weight is on the truck bed? In other words will it bent my bed or put dings in it or is all of the weight on the ball?
This will work with the Ford/Reese gooseneck ball not just the B&W ball?
Go with a hitch with the puck system ,or wait for Andersen ,and there puck system for the fifth wheel prep. Or go with bed rails , or better yet a picture frame ,and the Andersen . Do away with the gooseneck idea if there is a concern . - cummins2014Explorer
Chris
My question is, will B&W repair dented beds, because they certainly have damaged beds. I doubt there is any warranty for bed damage on B&W or Andersen.
Explain the safety chains ,and what Andersen is not truthful about, thats seems to be a new one, not heard that one from you guys before, but have heard plenty from you on the Andersen although you've never owned one. Just curious what they haven't been truthful about.
FYI Andersen is coming out with a puck system for all three GM ,ford, and Ram. Its in the works. You could have saved a little money not having to buy that expensive picture frame ,and B&W hitch ;) Oh! wait you are part of the Ram ,and B&W Mafia, Andersen wouldn't work with you guys :B - cummins2014Explorer
I contacted Anderson via their website yesterday and via Facebook today. If they don't respond then I will not be buying their product.
Their feedback is pretty fast, I have emailed them on a couple occasions , and they were pretty quick, and they are also easy to get ahold of by phone. - johndeerefarmerExplorer IIINobody is rushing them. I was just letting everyone know that have already asked them
- AllworthExplorer IICould it be that they do not work on the weekend??
- johndeerefarmerExplorer IIII contacted Anderson via their website yesterday and via Facebook today. If they don't respond then I will not be buying their product.
- Me_AgainExplorer III
Chris - sayoungExplorer
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
