kroghville's avatar
kroghville
Anode rod
I'm thinking it's time to replace the anode rod in my water heater. Which is the best to use, Aluminum or Magnesium? Thanks,
  • Depends on your water source. Magnesium dissolves faster in high mineral water and may give off a sulfur smell. Aluminum will last longer in this situation. If you use a good water source (low in minerals) then the magnesium should work fine.
  • I think the magnesium ones have a weld spot on the end of the bolt head. So looking at the head of the bolt, in the center, there is a round protrusion sticking out, maybe 1/4 of an inch round.
    Look and see what is in yours.
  • Magnesium is more reactive. It protects better but will wear faster.
  • The only ones I know of are aluminum. Take old rod or water heater model
    to RV Parts store. Not expensive.
