tj9267inIndy wrote:
I too have had issues with the OEM tires on my 2012 Montana. Last was two weeks ago on a trip to Sevierville, TN from Indiana. TPMS alarm went off, but not until after the tire had blown and damaged the rear sheet metal over the tires. Goodyear Marathon tires 235/80 R16 tires. This is the third original tire that has gone the same route. Pressure and temperature were in the normal range prior to failure. Didn't hit anything. I think that Keystone put too light a tire on these units. Had a buddy with a 2010 Montana, very similar circumstances. I've upgraded now to 235/85 R16's. We'll see how those work. Higher speed rating and heavier load rating although I don't load my camper heavy, don't carry much water, and don't normally run more than 62 or 63 mph. My personal opinion is it's a Keystone issue and not necessarily a Goodyear issue.
Almost verbatim for my situation. Keystone with the same size Marathons. My last trip I had two blowouts within 100 miles. I checked the pressure before I departed that morning and everything was fine. An hour after I started out I was doing about 65 on the interstate and didn't hit anything and the tire blew taking the sheet metal on the side of the trailer with it..
