Fire19's avatar
Fire19
Another Salesman lied
Well the same old story talk to the trailer salesman oh Yes you have a 2000 Ford F350 Dually Diesel you have plenty of truck. Well I have always wondered if my truck was really rated for the 5th wheel that I have been pulling around for 4 years. Well there was no weight sticker on the trailer when I got it because it was bleached out and I looked on line data (Which is way off now that I have had the trailer weighed)Listed weight for GVWR at 12,300lb and Dry weight@ 9,000lb.
Well on the way home from Camping this last went by a weight scale at Flying J and boy the numbers are way off. The total rig weight with the family and the dog in it with no water in it is 21,400lb puts the trailer at 13,600lb 1,300lb over brochure weight:M well according a fifth wheel weight calculator I am fine with the following exceptions Truck GVW over by 240lb and Truck GCW over 1,440lb. The truck pulls fine and have not had any problems for the four years we have pulled I did add Air bags on the truck to take the sag out.
total weights from Cat Scale
Steer Axle 4,980lb Limits form Ford Sticker on Door Post 5,200lb
Drive Axle 6,460lb Limits form Ford Sticker on Door Post 8,250lb
Trailer Axle 10,000lb
Gross weight 21,440lb
Truck Weight with passengers is 8,105lb
Just to remind you have to weigh your rigs because salesman's and product brochures may be way off.
