rmoore0852's avatar
rmoore0852
Antifreeze in water pump
I have what I think is an unusual question. Search didn't help. I live in west TX, and we have mild winters. Might go down into the teens for a few nights, but nothing real crazy or long. I have several friends here that use the air adapters to blow out water lines, and they have never had a problem. We are intending on using the camper some even throughout the winter, so I really don't want to pump everything with antifreeze between every trip. All winter trips will be to campgrounds with hookups, no dry camping. I'm getting ready to winterize the rig this weekend and have a question.
Can I pump antifreeze through the water pump to fill it, then still use the camper on city water? I know after the initial fill I will have to flush out the antifreeze that got past the check valve, but once that is done shouldn't I be able to safely use the rest of the water system on city water while the pump stays full of AF?
I am trying to make it so that after every trip its a quick process of blow out lines, drain water heater, and antifreeze in the drain traps.
  • korbe wrote:
    If I was in your situation, I would drain the water heater and blow out the lines after each trip, and do it again after each winter trip. I wouldn't worry about the pink stuff
    This is what I recommend also. I unhook the outlet to my water pump and run it for 30 seconds to get residual water out of it after blowing out the lines. Gets well below zero in Syracuse and I've had no problems. We went to Myrtle beach in March last year and I blew it out again afterwards.
  • If I was in your situation, I would drain the water heater and blow out the lines after each trip, and do it again after each winter trip. I wouldn't worry about the pink stuff
  • The "pink stuff" RV antifreeze gets pumped through every line, hot and cold, in your camper. If you hook up city water, the city water will flush out all the "pink stuff". You'll have to "pump the pink" again to winterize again. Your pump (itself) may not need to be winterized again, but the rest of your lines will. You are winterizing much more than just your water pump.
    Attach a hose to the in-take side of your water pump. Put the end of the hose in a gallon of "pink stuff". Turn on your water pump at the switch and turn on each faucet one at a time till "pink" comes out of each faucet ... hot and cold. Bypass your water heater, otherwise you'll be pumping 6 gallons into the water heater. By-pass, you'll put nothing in the water heater. Drain the water heater completely and just leave it.
