bobbyg123
Sep 12, 2019Explorer
ependydad wrote:
I think you'll find that most winterize with pink stuff. Some blow out the lines first and then push in pink stuff.
But there's also people who just use air.
The big challenge with air-only is making sure you get it out of all low points. The one issue I had was the toilet's water valve held water and broke one winter. $35-45 later and it was fixed up.
Yes, that's a valid concern. My issue is that I store the camper off site for a few months and use it during the winter months. Using air only to winterize is so much easier for this, as I don't have to de-winterize by flushing the pink stuff out, and then reapply the antifreeze 3-4 different cycles of use.
I'll probably continue to use the air only method, but I'm a stand up guy and will come clean to everyone here if I suffer a cracked line, valve, or god forbid, a water pump due to freezing.
About Fifth Wheel Group
