Terryallan
Sep 12, 2019Explorer II
ReneeG wrote:ependydad wrote:
I think you'll find that most winterize with pink stuff. Some blow out the lines first and then push in pink stuff.
But there's also people who just use air.
The big challenge with air-only is making sure you get it out of all low points. The one issue I had was the toilet's water valve held water and broke one winter. $35-45 later and it was fixed up.
Same here. We used to do just air, but missed this part of the toilet and had to replace it the next spring. A bit of a hassle. It's doable to just keep that valve open while blowing the air. What I don't like about the pink stuff is the taste and smell in the lines no matter how much you flush it out.
If you missed it with air. You would have missed it with AF as well. You have to open the valve either way.
About Fifth Wheel Group
