cummins2014
Sep 15, 2019Explorer
pianotuna wrote:
One that doesn't use oil.TomS1345 wrote:
What is a good air compressor to blow out lines?
That’s helps, I have one , but have you seen what comes out when you drain one ?
I don’t worry I don’t blow the lines.
I open the two low point drains , open all the faucets etc , that allows all the lines that can drain out , drain . Drain the water heater , all the tanks. Bypass the water heater , and fill the lines with AF. Fill the traps with AF . Finished
About Fifth Wheel Group
