happy2rv
Sep 15, 2019Explorer
cummins2014 wrote:
That’s helps, I have one , but have you seen what comes out when you drain one ?
I don’t worry I don’t blow the lines.
I use an oil less compressor with an in line air filter. Set the regulator to less than 60 PSI and I make sure to take the air out of the top of the compressor tank, not the water out of drain at the bottom of the tank ;). Is the air completely clean? Likely not.
I don't worry too much about it because before I use it again I will do a full sensitization and system flush.
About Fifth Wheel Group
