cummins2014
Sep 16, 2019Explorer
happy2rv wrote:cummins2014 wrote:
That’s helps, I have one , but have you seen what comes out when you drain one ?
I don’t worry I don’t blow the lines.
I use an oil less compressor with an in line air filter. Set the regulator to less than 60 PSI and I make sure to take the air out of the top of the compressor tank, not the water out of drain at the bottom of the tank ;). Is the air completely clean? Likely not.
I don't worry too much about it because before I use it again I will do a full sensitization and system flush.
There is no wrong way here, but some need to be aware of what they are blowing into those lines. Used AF for years with no issues.
About Fifth Wheel Group
