fj12ryder
Jun 17, 2016Explorer III
I got just the one sensor to try it out. It does work well, and it's been a couple months and it's still on the same battery.
It seems to work very well although the range isn't great. The main issue I have is that my wireless meat thermometer and the tank sensor interfere with each other and I can't get readings from either. I didn't get the monitor and use a tablet with their app for checking the level.
Because of the issues with the wireless meat thermometer, I just use it to check LP level before I start smoking. Unless you sync it, it only checks the level and transmits every half hour. Which is plenty I would imagine, and better for battery life.
I smoked some ribs the other day and had the smoker on for about 5 hours and, according to the gauge, the level in my 30 lb. tank went from 98 percent to 93 percent. That seems about right based on past experience.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
