Tibbs54 wrote:
The dealer has listed these as "standard build options":
Additional fan vent in bedroom
Mor/ryde pin box
Thermal pane windows If the dual pane definitely
Air hide-a-bed with pillows Nah, PITA to put up and down
Fan vent with remote/Tstat/rain sensor Ok
Powered sliding stab jacks, rear YES
Travel'R awning adj pitch hardware ????
6v batteries Depends on type of camping.
Generator? Get the Gen Prep
Awning toppers? Jury's out
15k air conditioning with ducting? Yes, no doubt
Vent in bathrooms? Yes
Central vac system. No
Storm windows? ??? Dual Pane???
Holding tank heat pads? In Colorado, YES
50 amp service? Definitely
4 point leveling system? Probably not
6 point leveling system? Same
Road trip sat (dish/direct) (HD sat... Call for options)? Nah
Winegard satellite / TV antenna combo? ????
BBQ grill with bracket? I put mine on the picnic table
Rear view camera? Maybe
All listed are my personal preferences. If you're heading south in the summer get another AC and have it tied into the duct and thermostat. On the Gen Prep you don't have to add the genny if you don't want to but having it ready to go is nice if you decide you need one. On the leveling system; On mine when I get the truck unhitched I'm halfway there as I level side-to-side first, unhitch and then front to back is easy. The leveling system does add stability for those who don't like a little shaking, doesn't bother us. Satellite?? I have a tripod and it doesn't take long to set up. I guess a lot depends on how much time you are going to spend in the camper. We go camping to get out and about not sit in the trailer and look at TV. I can do that at home.
Bottom line, if your pockets are real deep get everything otherwise pick and choose. You have a lot of good advice here...
