jrs1871
Apr 22, 2015Explorer
A word of caution. Those Nev-R-Lube bearings can fail and seize up. A member of the club had that happen on his Cedar Creek with considerably less than 100,000 miles. The pic he took of the failed bearing looked as if there was no grease in there.
I also believe there has been some problems with the EZ Flex due to bad rubber. When you crawl under there to grease the zerks on the wet bolts, it is easy to give them a once over.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
