skipnchar
Jun 18, 2013Explorer
Hay you could probably sell TICKETS to the event if you try that. Easiest fix is to find a dump station that uses a PIT to collect sewage and simply loosen the valve and allow LIQUID to drain before removing and replacing the valve. I've had to do it on the road (while traveling) before and it's not that bad a job. Just choose the dump station wisely.
About Fifth Wheel Group
