joebedford's avatar
joebedford
Nomad III
Dec 20, 2022
Lasalle Bristol dump valves jammed closed
I'm helping a friend with a new to him 5er that has all valves stuck in the closed position. I have Valterra valves and I know you can grab the shaft with vice grips and pull it open.
However his is 'equipped' with Lasalle Bristol valves where the shaft is hidden inside a plastic shell.
Is there any way to access that pull shaft by removing the case?
Barring that, on my rig, I was able to replace the valve and cable by removing 4 bolts, slipping the old valve out and slipping the new one it. Can this be done with Lasalle Bristol valves? (it sure looks like it)
  • The pro was able to undo one cable and reef the valve open. The other two had no success (yet). On one he declared that the rod had stripped out of the valve and no decision on the third.
    I believe the owner is going to replace all valves with not Lasalle Bristol valves.
  • 3_tons's avatar
    3_tons
    Explorer III
    joebedford wrote:
    We're in Florida so no freezing temperatures until later this week.
    Ha, seems like ‘everything’ is better in Florida :) !!
    3 tons
  • Following directions for cable replacement, see if cable is seized or whether it is actually the valve seized.
  • We're in Florida so no freezing temperatures until later this week.
    Neither of us wants / is able to replace the valves so he's going to call a pro to find out what he says. I'll let you know.
  • 3_tons's avatar
    3_tons
    Explorer III
    Try a hair dryer, maybe they're frozen…
    3 tons
