lamopar's avatar
lamopar
Lasalle dump valves to Valterra
So my current trailer has what looks like Lasalle cable type dump valves. I bought electric controls that go on a Valterra valve. Just curious if anyone would know if the middle of the valves could interchange so I don't have to re-manufacture the entire drain system.
My thought is to purchase a Valterra 3" dump valve and remove the 4 bolts holding it together along with the same on the trailer and just change out the middle part leaving the sides in place.
Anyone have any experience at this?
1 Reply
  • So to follow up on the problem. First off the Lasalle valves are also called Baxter. They seem to be pretty popular. The bolt pattern is the same as the Valterra so I don't need to by the different valves. I am installing electric motors to the top of the valve to eliminate the cable.
    So far for this installation I only need to grind off a support bump that runs between the bolts on the 3" valve so the motor mount plate can sit flat against the valve.
    I pulled the plumbing off the trailer by removing the bolts holding the valves together so I was able to look at it in sections and test the valves and fittings before reinstalling it. I cannot find my plumbers grease for the valve reassembly so I will get it back together tomorrow.
    I'm taking some pictures so I will post them when I finish if it all works.
