lamopar
Sep 13, 2021Explorer
So to follow up on the problem. First off the Lasalle valves are also called Baxter. They seem to be pretty popular. The bolt pattern is the same as the Valterra so I don't need to by the different valves. I am installing electric motors to the top of the valve to eliminate the cable.
So far for this installation I only need to grind off a support bump that runs between the bolts on the 3" valve so the motor mount plate can sit flat against the valve.
I pulled the plumbing off the trailer by removing the bolts holding the valves together so I was able to look at it in sections and test the valves and fittings before reinstalling it. I cannot find my plumbers grease for the valve reassembly so I will get it back together tomorrow.
I'm taking some pictures so I will post them when I finish if it all works.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
