JohnInBurnsvill's avatar
Jun 26, 2023
Bristol dump valve compatibility
My black water dump fell pipe from its bracket and dragged on the road. The valve is a Bristol but only the outer part is damaged. Can I buy a Valterra or Camco valve which is cheaper and will the screws align or should I buy a new Bristol and only use part of it? I don't want to cut the whole valve off and then have to extend the pipe in order to glue a new valve on. Maybe a new Bristol won't even match the old Bristol.
1 Reply
    I had to replace a T-handle on my grey water valve which had fallen off somewhere. None of the Valterra's would work because the handle needed a hole through the middle for a screw to screw into the tube coming out. I ordered the Bristol off Amazon and it fit perfectly. I don't know if that particular valve is Bristol or not as it's a remote release and I would have to get back up under the coach. Other valves on my coach are Valterra. Not sure why this handle was different.
    Dale
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
