jimmyfredExplorerJun 18, 2013Assume My Dump Valve is Closed and Won't Open !...........So what pump do I Need so I can run a hose down into the black tank via the commode and siphon out the contents and then replace the dump valve ? , thanks , jigger
ereed52ExplorerJun 18, 2013Wet/Dry Vac. One with drain hole, so you can run hose from that to your sewer connection.
Related ContentNever Assume !Grey Tank Valve Stuck ClosedLasalle Bristol dump valves jammed closedBlack Water Valve Will Not CloseWhy assume I like your music
