jimmyfredExplorerJun 18, 2013Assume My Dump Valve is Closed and Won't Open !...........So what pump do I Need so I can run a hose down into the black tank via the commode and siphon out the contents and then replace the dump valve ? , thanks , jigger
fishingbob61ExplorerJun 19, 2013You might call one of the PORTA SANS cos they pump out the portable laves, it might work for you?
Related ContentNever Assume !Grey Tank Valve Stuck ClosedLasalle Bristol dump valves jammed closedBlack Water Valve Will Not CloseWhy assume I like your music
