jimmyfred's avatar
jimmyfred
Assume My Dump Valve is Closed and Won't Open !
...........So what pump do I Need so I can run a hose down into the black tank via the commode and siphon out the contents and then replace the dump valve ? , thanks , jigger
  • Have you looked at the valve? The problem is frequently a broken or loose cable.
