jimmyfredExplorerJun 18, 2013Assume My Dump Valve is Closed and Won't Open !...........So what pump do I Need so I can run a hose down into the black tank via the commode and siphon out the contents and then replace the dump valve ? , thanks , jigger
31 RepliesReplies sorted by NewestShow MoreagesilausExplorer IIIJun 18, 2013Have you looked at the valve? The problem is frequently a broken or loose cable.
Related ContentNever Assume !Lasalle Bristol dump valves jammed closedGrey Tank Valve Stuck ClosedBlack Water Valve Will Not CloseWhy assume I like your music
