Colo Native wrote:
donn0128 wrote:
Why do you think the pin is too high?
Pin is generally around 20% of the fivers actual weight. Not the mythical brochure dry weight.
20% of the trailer weight is 1640 and the difference in towing and not on the rear is 2360 or am I missing something? And if I add water it will increase by some amount.
According to those numbers your trailer weighs 10,560 lbs. and 20% of that is 2112 lbs. You have 2360 lbs. of pin weight. Well within the norm of 20-24%. I'd be more concerned about the fact that you are within 20 lbs. of your RAWR.
Your front axle weight dropped quite a bit with the 5th wheel hooked up, you may have the hitch a little too far behind the axle resulting in increased rear axle weight and lessened front axle weight.
