fj12ryder wrote:
Colo Native wrote:
donn0128 wrote:
Why do you think the pin is too high?
Pin is generally around 20% of the fivers actual weight. Not the mythical brochure dry weight.
20% of the trailer weight is 1640 and the difference in towing and not on the rear is 2360 or am I missing something? And if I add water it will increase by some amount.
According to those numbers your trailer weighs 10,560 lbs. and 20% of that is 2112 lbs. You have 2360 lbs. of pin weight. Well within the norm of 20-24%. I'd be more concerned about the fact that you are within 20 lbs. of your RAWR.
Your front axle weight dropped quite a bit with the 5th wheel hooked up, you may have the hitch a little too far behind the axle resulting in increased rear axle weight and lessened front axle weight.
So your saying that I should move the hitch up, OK any idea how much? Also if the trailer weight is 10560 then the sticker on the trailer is 9931 that thing is over weight without any water on board correct?
