MFL wrote:
W5CI wrote:
It looks as if you have two options, Just live with it or upgrade to a 1 ton if you are really concerned, Thats what I did and only wish I had got it sooner. Good Luck
The OP actually has a 1 ton SRW 350, with a 250 badge, and ratings. He would need to go DRW, as you did, to gain real world capacity. He has added much aftermarket wt to the rear axle. He needs to transfer some back to the front, or like you say, just live with it.
Jerry
Will need to disagree this time, the 6,100# rear axle is not what you would find on a 11,700# GVWR SRW! Likely has 17" wheels and tire rating of 3,195 ea.
