taken wrote:
OP, you will be COMPLETELY fine. Does your 250 have the camper package? If so, it has the same rear upper overload spring the SRW 350 does. This spring is the only difference between the two models and if you do have the camper package, you are 100% physically identical to the SRW 350. If you don't you can either add it or a set of airbags to accomplish the same thing. So, while you may be over on paper, you are actually under in the real world.
Yes it has the camper pkg and snow plow pkg. I went out and moved the hitch up 1 hole which is all that's left and when I get a chance I will re weigh
